Time to get organized and rolling on panel. First pic is all the electronic boxes that need to be mounted behind the panel. Below yard stick is inside behind panel. Above is mounted in the engine area and firewall. Second pic shows the left side mounting area that will be under one of the access door. I built the alum partition so I could mount boxes on both sides. Panel is at the painters having a dark gray color put on it with a no glare clear coat.
